Adds the specified VLAN as a subscriber VLAN on the specified PVLAN.
| name | Specifies the name of the PVLAN to which the VLAN is added. |
| vlan_name | Specifies a VLAN to add to the PVLAN. |
| non-isolated | Configures the subscriber VLAN as a non-isolated subscriber VLAN. |
| port | Specifies the port that serves as the loopback port. |
If the non-isolated option is omitted, this command adds the specified VLAN as an isolated subscriber VLAN.
The VLAN must be created and configured with a tag before it is added to the PVLAN. If the non-isolated option is omitted, the VLAN is added as an isolated subscriber VLAN. If the non-isolated option is included, the VLAN is added as an non-isolated subscriber VLAN.
If two or more subscriber VLANs have overlapping ports (where the same ports are assigned to both VLANs), each of the subscriber VLANs with overlapping ports must have a dedicated loopback port.
The following example adds VLAN "restricted" as a subscriber VLAN for the PVLAN named "companyx":
configure private-vlan companyx add subscriber restricted isolated
This command is available on all platforms that support the Private VLAN feature. For features and the platforms that support them, see the Switch Engine v33.1.1 Licensing Guide document.
